16 years agoModling a State Machine in VHDL ... with trouble memorizing variables
Hi, I'm trying to make a state-machine wich remains in one of the states until one of the variables goes from zero to one three times. I assume it should be quite simple, but after some days I ...
16 years agoThanks. I did not know I could not use it inside the combinational process. But - as far as I have seen - I can not do it either making a control like:
if (signal_to_monitor'event and signal_to_monitor='1') then accumulate<=accumulate+1 ;end if; (I include a sample code at the end) The intended behaviour I tried was just to 'stay in one state till the signal makes a number of changes (three in the example)'. It has no other application. So, I wanted to stay in the first state till the signal goes from 0 to 1. Then stay in second_st till 3 changes have been made in the signal (from 0 to 1). Once that happens (accumulate=3), return to first state and reset accumulate. How can I do this? (the only solution is creating additional states like one_change, two_changes and three_changes? ) (if so, what if I needed 50 changes??? :( ) Thanks! -- process (state,signal_to_monitor) begin next_state <= state; if (signal_to_monitor'event and signal_to_monitor='1') then accumulate<=accumulate+1 ;end if; case state is when first_st => -- no ticks yet if ( signal_to_monitor ='1') then -- count one tick and go to the 'counting' state next_state <= second_st; else accumulate <=0; next_state <= first_st; end if; when second_st => -- if the signal goes to one again, count one more till you arrive to NUM_TICKS -- then fall back to first_state if (accumulate = NUM_TICKS) then -- next_state<=first_st; end if; end case;
