16 years agoModling a State Machine in VHDL ... with trouble memorizing variables
Hi, I'm trying to make a state-machine wich remains in one of the states until one of the variables goes from zero to one three times. I assume it should be quite simple, but after some days I ...
16 years agoSorry! I tried to translate the code for a better understanding. I resend it with the necessary corrections (and in fact the full code I'm working with). I attach also the simulation result (why does the accumulate signal - and so the output - go from 0 to 1 without control????):
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity Counter is -- counts three ticks of the signal signal_to_monitor -or thats what I wish -- the output signal is integer just to show the evolution in the waveform simulator port( clk: in std_logic; reset,signal_to_monitor: in std_logic; output: out integer ); end Counter; architecture Behavioral of Counter is constant NUM_TICKS : integer := 3; type possible_states is (first_st,second_st); signal next_state,state: possible_states; signal accumulate: integer range 0 to 2; begin RefreshState : process (clk,reset) begin if (reset='1') then state <= first_st; elsif (clk'event and clk='1') then state <= next_state; end if; end process RefreshState; process (state,signal_to_monitor) begin next_state <= state; case state is when first_st => -- no ticks yet if (signal_to_monitor ='1') then -- count one tick and go to the 'counting' state accumulate<=accumulate+1; next_state <= second_st; else accumulate <=0; next_state <= first_st; end if; when second_st => -- if the signal goes to one again, count one more till you arrive to NUM_TICKS -- then fall back to first_state if (signal_to_monitor = '1') then accumulate <=accumulate +1; end if; if (accumulate = NUM_TICKS) then -- next_state<=first_st; end if; end case; -- just to have a look at the waveform I generate the output here output <= accumulate; end process; process (state) begin --do nothing as the output has been generated just for debugging purposes end process ; end Behavioral;
