17 years agoModify IP-CORE Ssram
Hello, I'm trying to build a system in the SOPC-Builder with a Ssdram(Clock of whole system and components 100Mhz). The problem that I have is that running at 100 Mhz the IP-CORE of Ssram prod...
17 years agoThanks for the answer so quickly.
I kwnow that ssram supports 100Mhz and more frequency. The problem is that I have made a system running at 50Mhz and it goes, when I change to 100 Mhz in the Nios II appears an error telling me:" Verify failed between adress 0xXXXXX and 0xXXXXX". Then I reviewed the verilog code that SOPC Builder has made of the Ssram component and I doubt if the wait of read and write are well made, because the structure is a state machine which depends of the clock. So if the clock changes maby these times change. I don't kwnow enough of verilog so I'm a bit lost with the archive name.v and the other archive name.tcl that goes with the component, that's why I ask for help. I think that this is the problem, but maby(sure) I'm wrong, if anybody can suggest more ideas. P.D Sanmao: I have introduce the clock with the phase(-3ns) and the error continuos the same. Thanks a lot.
