16 years ago
Modelsim: Unknown State
In the modelsim simulation, there is a signal, delay1, shows its value and undefined state(red colour) periodically. It shouldn't show unknown state based on my code. I wonder why. Pls have a look on my code attached.
thanks
    --- Quote Start ---
    I can find the q1 and q2 under FIR(instantiation of Delay1_Redline).
    If run functional simulation in qii, there is always no problem with it.
    thanks
    --- Quote End ---
    your are right , I could also find q1 and q2.
    The reason for your problem is here :
    if (count2 < 57)
    begin
    no_shiftreg <= no_shiftreg + 1; // +1
    end
    else
    begin
    no_shiftreg <= 0; -- here you set shift_reg to "0"
    end
    if (count<count_half)
    begin
    delay1 <= q2[no_shiftreg]; -- here you set delay1 to q[0]
    end -- but q[0] is not defined,
    else -- reg [signal_mag_w-1:0] q1 [num_shiftreg:1];
    begin
    delay1 <= q1[no_shiftreg];
    end
    Kind regards
    GPK
    thanks
    --- Quote Start ---
    I'm not a verilog expert, but it seems that you define q1 and q2 as tables with indexes between 1 and num_shiftreg, and set delay1 with q1[no_shiftreg] or q2[no_shiftreg].
    But you also initialize no_shiftreg with the value 0. So in those cases delay1 will take an uninitialized value. You should either initialize no_shiftreg with 1 or use q1[no_shiftreg+1] / q2[no_shiftreg+1]
    --- Quote End ---
    Hi Daixiwen,
    you are right. q1[0] and q2[0] are never intialized, but used as input for Delay1.
    Kind regards
    GPK
    --- Quote Start ---
    thanks
    --- Quote End ---
    I run your design with modelsim and I can confirm your problem. What I'm wondering
    about is that I could not find the signals q1 and q2 in the Waveforms. Maybe I missed something.
    I also setup a Quartus project and generate a netlist for simulation. With the netlist the unknow is gone. Maybe you can try it by yourself ?
    Kind regards
    GPK
