11 years agoModelSim on Fedora 20
I've installed ModelSim into my fedora 20, and when I change the directory to: /altera/14.1/modelsim_ase/linuxaloem/ And I tried to run ModelSim with command: ./vsim But there were errors pop up:./vish: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory Then, I googled online found I need to install 32 bit library, so then, I run the command: sudo yum install libXft.i686 But then, the problem remains. Same error as I listed above. Anyone can help?2 Replies
The error is complaining about libncurses, you installed libXft
Try "sudo yum install ncurses-libs.i686" and see if the error changes. The last time I installed Quartus/Modelsim, the installer listed the packages it thought you needed to install. Did you install those packages? If not, then you may end up with a long list of things you need to "yum install" See page 4: http://www.altera.com/literature/manual/quartus_install.pdf - Altera_Forum
Thanks, that worked.
