16 years agoModelSim: No Output
Hi. I try to simulate a design. there is output in Quartus II(Timing Simulation). But not in modelsim. May i know the reason? i am just new to modelsim.. FYI, my design just need the input ...
16 years agoYou don't necessarily need a testbench. You can assign a clock waveform to an input signal using the clock command.
Select your signal in the wave window, or in the object pane of the main window, right click to get a context menu, and select the clock menu item. A testbench will make your life easier though. For a trivial testbench like this, you can embed it in your top entity/module, if you want.
