15 years agoModelsim Help
I am learning modelsim and verilog
I have created a module and testbench but in simulation using the command: vsim -novopt "testbench name" I keep getting an initial high z input and don't care outputs. Perhaps it is something in my code? Original code: module threeBitCounter ( counterValue, count, reset, clock); input count; // Increment our counter on rising edge of 'count' input reset; // Reset our counter on rising edge of 'reset' input clock; // Synchronize outputs to clock output reg [2:0] counterValue; // Internally store the counter value // This takes care of synchronously driving the outputs always @ ( posedge clock or negedge reset ) begin if( reset == 1'b0 ) counterValue <= 3'b000; else if( count ) counterValue <= counterValue + 1'b1; else counterValue <= counterValue; end endmodule TestBench code: `timescale 1 ns / 1 ns module threeBitCounter_testbench; //define inputs/outputs wire [2:0] cval; reg reset; reg clk; reg countThisEvent; threeBitCounter I1 ( cval, countThisEvent, reset, clock); //set clock always # 10 clk = ~clk; //Exercise the Counter initial begin reset = 1'b1; clk = 1'b0; countThisEvent = 1'b0; # 4 reset = 1'b0; # 4 reset = 1'b1; # 7 countThisEvent = 1'b1; # 20 countThisEvent = 1'b0; # 20 countThisEvent = 1'b0; # 20 countThisEvent = 1'b0; # 20 countThisEvent = 1'b1; # 20 countThisEvent = 1'b0; # 20 countThisEvent = 1'b0; # 20 countThisEvent = 1'b0; end endmodule1 Reply
change to:threeBitCounter I1 ( cval, countThisEvent, reset, clock);threeBitCounter I1 ( cval, countThisEvent, reset, clk);
