11 years agoModelSim error
Hi!
I get frustrating error many times when i start ModelSim. It says: VHDL Compiler exiting End then:# ** Error: C:/altera/14.1/modelsim_ase/win32aloem/vcom failed. Why is this happening? My solution has been the create a new project, and then it usally work, but takes a lot longer. Would have been nice to find a fix. The process has been: 1. Write the code. 2. Start compiling - Non error. 3. Start test bench. 4. Start simulation tool. Then the error above shows. Thanks for answers :)1 Reply
I found the solution to the issue. You cant use Norwegian æ and å, for the name for the folders you use for the project :P
