15 years ago
modelsim error when simulate : cannot load \eda\mentor\modelsim\convert_hex2ver.dll
I'm using Modelsim 6.6d starter edition.
I've tried searching the forums here and the "web", but sadly all I found was a bunch of people saying to add Veriuser = "\eda\mentor\modelsim\convert_hex2ver.dll" in the modelsim.ini file or to remove it.
I did both, added and removed the modelsim.ini file from my project folder, modified both the project one and the altera install folder's .ini for modelsim.
Nothing works. It just keeps asking for "\eda\mentor\modelsim\convert_hex2ver.dll" because it can't find it.
I'm not very sure what to do. I could simulate perfectly yesterday with an other project but now I can't with this new one. And it's doing next to nothing, too. Only a clock division module... ?!?
Any ideas would be greatly appreciated.
<<<*EDIT*<<<
The exact full errors are:
# ** Error: (vsim-3193) Load of "\eda\mentor\modelsim\convert_hex2ver.dll" failed: File not found.# ** Error: (vsim-PLI-3002) Failed to load PLI object file "\eda\mentor\modelsim\convert_hex2ver.dll".
>>>*EDIT*>>>
    Here is the problem module...
    `timescale 1ns/1ns
    module VGA_1
        CLOCK_50, KEY,
        VGA_CLK, VGA_R, VGA_G, VGA_B, VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N
    input CLOCK_50;
    input  KEY;
    wire CLOCK_50;
    wire  KEY;
    output VGA_CLK;
    output  VGA_R, VGA_B, VGA_G;
    output VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N;
    wire VGA_CLK;
    reg  VGA_R = 8'd0;
    reg  VGA_B = 8'd0;
    reg  VGA_G = 8'd0;
    reg VGA_HS = 1'b1;
    reg VGA_VS = 1'b1;
    wire VGA_BLANK_N;
    reg VGA_SYNC_N = 1'b1;
    wire rst;
    assign rst = ~KEY;
    // 25 MHz clock generation
    reg clk_25M_cnt = 1'b0;
    reg clk_25M = 1'b0;
    assign VGA_CLK = clk_25M;
    always @ (posedge CLOCK_50 or posedge rst)
    begin
        if(rst)
        begin
            clk_25M_cnt <= 1'b0;
            clk_25M <= 1'b0;
        end
        else
        begin
            if(clk_25M_cnt)
            begin
                clk_25M <= ~clk_25M;
            end
            else
            begin
                clk_25M_cnt <= 1'b1;
            end
        end
    end
    // Color output generation
    reg  vga_state = 2'd0;
    begin
        if(rst)
        begin
            VGA_R <= 8'd1;
            VGA_G <= 8'd0;
            VGA_B <= 8'd0;
        end
        else
        begin
            if((VGA_R == 8'd0) || (VGA_R == 8'd255))
            begin
                VGA_R <= 8'd0;
                if((VGA_G == 8'd0) || (VGA_G == 8'd255))
                begin
                    VGA_G <= 8'd0;
                    if((VGA_B == 8'd0) || (VGA_B == 8'd255))
                    begin
                        VGA_B <= 8'd0;
                        VGA_R <= VGA_R + 8'd1;
                    end
                    else
                    begin
                        VGA_B <= VGA_B + 8'd1;
                    end
                end
                else
                begin
                    VGA_G <= VGA_G + 8'd1;
                end
            end
            else
            begin
            end
            case (vga_state)
                2'd0:begin
                    vga_state <= vga_state + 2'd1;
                end
                2'd1:begin
                end
                2'd2:begin
                end
                2'd3:begin
                end
                default:begin
                    vga_state <= 2'd0;
                end
            endcase
        end
    end
    // Blanking signal generation
    assign VGA_BLANK_N = (vga_blanking_h && vga_blanking_v);
    // Sync signal generation for horizontal
    reg  vga_disp_cnt_h = 0;
    reg vga_blanking_h;
    // Horizontal counter
    begin
        if(rst)
        begin
            vga_disp_cnt_h <= 0;
        end
        else
        begin
            if(vga_disp_cnt_h == 1600)            // 800 pixels
            begin
            end
            else
            begin
                vga_disp_cnt_h <= vga_disp_cnt_h + 12'd1;
            end
        end
    end
    // Horizontal sync
    begin
        if(rst)
        begin
            VGA_HS <= 1'b1;
            vga_blanking_h <= 1'b1;
            VGA_SYNC_N <= 1'b1;
        end
        else
        begin
            // Front porch (16 pixels)
            if(vga_disp_cnt_h >= 1568)    // 784 pixels
            begin
                VGA_HS <= 1'b1;
                vga_blanking_h <= 1'b0;
                VGA_SYNC_N <= 1'b1;
            end
            // Horizontal sync (96 pixels)
            else if(vga_disp_cnt_h >= 1376)    // 688 pixels
            begin
                VGA_HS <= 1'b0;
                VGA_SYNC_N <= 1'b1;
            end
            // Back porch (48 pixels)
            else if(vga_disp_cnt_h >= 1280)    // 640 pixels
            begin
                VGA_HS <= 1'b1;
                VGA_SYNC_N <= 1'b1;
            end
            // Pixel dipsplay time (640 pixels)
            else if(vga_disp_cnt_h >= 0)        //   0 pixels
            begin
                VGA_HS <= 1'b1;
                VGA_SYNC_N <= 1'b1;
            end
        end
    end
    // Sync signal generation for vertical
    reg  vga_disp_cnt_v = 0;
    reg vga_blanking_v;
    // Vertical counter
    begin
        if(rst)
        begin
            vga_disp_cnt_v <= 0;
        end
        else
        begin
            if(vga_disp_cnt_v == 525)            // 525 lines
            begin
            end
            else
            begin
                if(vga_disp_cnt_h == 1376)
                begin
                    vga_disp_cnt_v <= vga_disp_cnt_v + 11'd1;
                end
            end
        end
    end
    // Vertical sync
    begin
        if(rst)
        begin
            VGA_VS <= 1'b1;
            vga_blanking_v <= 1'b1;
        end
        else
        begin
            // Front porch (10 lines)
            if(vga_blanking_v >= 515)            // 515 lines
            begin
                VGA_VS <= 1'b1;
                vga_blanking_v <= 1'b0;
            end
            // Vertical sync (2 lines)
            else if(vga_blanking_v >= 513)    // 513 lines
            begin
                VGA_VS <= 1'b0;
            end
            // Back porch (33 lines)
            else if(vga_blanking_v >= 480)    // 480 lines
            begin
                VGA_VS <= 1'b1;
            end
            // Line dipsplay time (480 lines)
            else if(vga_blanking_v >= 0)        //   0 lines
            begin
                VGA_VS <= 1'b1;
            end
        end
    end
    endmodule
    And the test bench for modelsim...
    `timescale 1ns/1ns
    module VGA_1_TB
    reg clk = 1'b0;
    reg  KEY = 1'b0;
    wire VGA_CLK;
    wire  VGA_R;
    wire  VGA_B;
    wire  VGA_G;
    wire VGA_HS;
    wire VGA_VS;
    wire VGA_BLANK_N;
    wire VGA_SYNC_N;
    VGA_1 u (clk, key, VGA_CLK, VGA_R, VGA_G, VGA_B, VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N);
    initial
    begin
     # 0  clk = 1'b0;
    end
    always
    begin
     # 5  clk = ~clk;
    end
    endmodule
    Basically, get the error I mentioned whenever I try to simulate.
    And now, when I try to simulate another project that used to be working, I get an error too.
    All went to **** overnight. It worked one evening and didn't the next morning... without any changes to my computer, OS, etc.
    Any help is greatly appreciated !
    *bump*
    I'm pretty sure I can't be the only one with this or a similar error. Even Altera's knowledge base had a page on something similar...
    Any ideas, anyone ?
    Thanks!
