15 years agomodelsim error when simulate : cannot load \eda\mentor\modelsim\convert_hex2ver.dll
I'm using Modelsim 6.6d starter edition. I've tried searching the forums here and the "web", but sadly all I found was a bunch of people saying to add Veriuser = "\eda\mentor\modelsim\convert_h...
15 years agoHere is the problem module...
`timescale 1ns/1ns
module VGA_1
CLOCK_50, KEY,
VGA_CLK, VGA_R, VGA_G, VGA_B, VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N
input CLOCK_50;
input KEY;
wire CLOCK_50;
wire KEY;
output VGA_CLK;
output VGA_R, VGA_B, VGA_G;
output VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N;
wire VGA_CLK;
reg VGA_R = 8'd0;
reg VGA_B = 8'd0;
reg VGA_G = 8'd0;
reg VGA_HS = 1'b1;
reg VGA_VS = 1'b1;
wire VGA_BLANK_N;
reg VGA_SYNC_N = 1'b1;
wire rst;
assign rst = ~KEY;
// 25 MHz clock generation
reg clk_25M_cnt = 1'b0;
reg clk_25M = 1'b0;
assign VGA_CLK = clk_25M;
always @ (posedge CLOCK_50 or posedge rst)
begin
if(rst)
begin
clk_25M_cnt <= 1'b0;
clk_25M <= 1'b0;
end
else
begin
if(clk_25M_cnt)
begin
clk_25M <= ~clk_25M;
end
else
begin
clk_25M_cnt <= 1'b1;
end
end
end
// Color output generation
reg vga_state = 2'd0;
begin
if(rst)
begin
VGA_R <= 8'd1;
VGA_G <= 8'd0;
VGA_B <= 8'd0;
end
else
begin
if((VGA_R == 8'd0) || (VGA_R == 8'd255))
begin
VGA_R <= 8'd0;
if((VGA_G == 8'd0) || (VGA_G == 8'd255))
begin
VGA_G <= 8'd0;
if((VGA_B == 8'd0) || (VGA_B == 8'd255))
begin
VGA_B <= 8'd0;
VGA_R <= VGA_R + 8'd1;
end
else
begin
VGA_B <= VGA_B + 8'd1;
end
end
else
begin
VGA_G <= VGA_G + 8'd1;
end
end
else
begin
end
case (vga_state)
2'd0:begin
vga_state <= vga_state + 2'd1;
end
2'd1:begin
end
2'd2:begin
end
2'd3:begin
end
default:begin
vga_state <= 2'd0;
end
endcase
end
end
// Blanking signal generation
assign VGA_BLANK_N = (vga_blanking_h && vga_blanking_v);
// Sync signal generation for horizontal
reg vga_disp_cnt_h = 0;
reg vga_blanking_h;
// Horizontal counter
begin
if(rst)
begin
vga_disp_cnt_h <= 0;
end
else
begin
if(vga_disp_cnt_h == 1600) // 800 pixels
begin
end
else
begin
vga_disp_cnt_h <= vga_disp_cnt_h + 12'd1;
end
end
end
// Horizontal sync
begin
if(rst)
begin
VGA_HS <= 1'b1;
vga_blanking_h <= 1'b1;
VGA_SYNC_N <= 1'b1;
end
else
begin
// Front porch (16 pixels)
if(vga_disp_cnt_h >= 1568) // 784 pixels
begin
VGA_HS <= 1'b1;
vga_blanking_h <= 1'b0;
VGA_SYNC_N <= 1'b1;
end
// Horizontal sync (96 pixels)
else if(vga_disp_cnt_h >= 1376) // 688 pixels
begin
VGA_HS <= 1'b0;
VGA_SYNC_N <= 1'b1;
end
// Back porch (48 pixels)
else if(vga_disp_cnt_h >= 1280) // 640 pixels
begin
VGA_HS <= 1'b1;
VGA_SYNC_N <= 1'b1;
end
// Pixel dipsplay time (640 pixels)
else if(vga_disp_cnt_h >= 0) // 0 pixels
begin
VGA_HS <= 1'b1;
VGA_SYNC_N <= 1'b1;
end
end
end
// Sync signal generation for vertical
reg vga_disp_cnt_v = 0;
reg vga_blanking_v;
// Vertical counter
begin
if(rst)
begin
vga_disp_cnt_v <= 0;
end
else
begin
if(vga_disp_cnt_v == 525) // 525 lines
begin
end
else
begin
if(vga_disp_cnt_h == 1376)
begin
vga_disp_cnt_v <= vga_disp_cnt_v + 11'd1;
end
end
end
end
// Vertical sync
begin
if(rst)
begin
VGA_VS <= 1'b1;
vga_blanking_v <= 1'b1;
end
else
begin
// Front porch (10 lines)
if(vga_blanking_v >= 515) // 515 lines
begin
VGA_VS <= 1'b1;
vga_blanking_v <= 1'b0;
end
// Vertical sync (2 lines)
else if(vga_blanking_v >= 513) // 513 lines
begin
VGA_VS <= 1'b0;
end
// Back porch (33 lines)
else if(vga_blanking_v >= 480) // 480 lines
begin
VGA_VS <= 1'b1;
end
// Line dipsplay time (480 lines)
else if(vga_blanking_v >= 0) // 0 lines
begin
VGA_VS <= 1'b1;
end
end
end
endmodule
And the test bench for modelsim...
`timescale 1ns/1ns
module VGA_1_TB
reg clk = 1'b0;
reg KEY = 1'b0;
wire VGA_CLK;
wire VGA_R;
wire VGA_B;
wire VGA_G;
wire VGA_HS;
wire VGA_VS;
wire VGA_BLANK_N;
wire VGA_SYNC_N;
VGA_1 u (clk, key, VGA_CLK, VGA_R, VGA_G, VGA_B, VGA_HS, VGA_VS, VGA_BLANK_N, VGA_SYNC_N);
initial
begin
# 0 clk = 1'b0;
end
always
begin
# 5 clk = ~clk;
end
endmodule
Basically, get the error I mentioned whenever I try to simulate. And now, when I try to simulate another project that used to be working, I get an error too. All went to **** overnight. It worked one evening and didn't the next morning... without any changes to my computer, OS, etc. Any help is greatly appreciated !
