[MODELSIM_ASE] Install on recent Linux (Fedora 21)
I would like to use free modelsim on my Fedora 21 but when I launch ModelSim I get this echo on terminal :
Code:
Error in startup script:
Initialization problem, exiting.
while executing
"EnvHistory::Reset"
(procedure "PropertiesInit" line 3)
invoked from within
"PropertiesInit"
invoked from within
"ncFyP12 -+"
(file "/opt/altera/modelsim_ase/linux/../tcl/vsim/vsim" line 1)
** Fatal: Read failure in vlm process (0,0)
A man explain the methot do install modelsim on recent linux
http://mattaw.blogspot.fr/2014/05/ma...r-edition.html
He said ModelSim use only an old freetype. The methon consist to make an old freetype from source code
CONFIG OF MY PC :
I use Fedora 21 64bits.
I installed complet gcc tool chain with [yum groupinstall "Development Tools" "Development Libraries"]
I have gcc (GCC) 4.9.2 20141101 (Red Hat 4.9.2-1)
Gcc work fine with simple test program.
MY WORK TO SOLVE MY PROBLEM :
I download old freetype source code : http://sourceforge.net/projects/free...etype2/2.4.12/
I untar the archive and run 'autogen.sh'
I use the config script like this : ./configure --build=i686-pc-linux-gnu "CFLAGS=-m32" "CXXFLAGS=-m32" "LDFLAGS=-m32"
And I get error on terminal :
Code:
reeType build system -- automatic system detection
The following settings are used:
platform unix
compiler cc
configuration directory ./builds/unix
configuration rules ./builds/unix/unix.mk
If this does not correspond to your system or settings please remove the file
`config.mk' from this directory then read the INSTALL file for help.
Otherwise, simply type `make' again to build the library,
or `make refdoc' to build the API reference (the latter needs python).
cd builds/unix; /bin/sh ./configure '--build=i686-pc-linux-gnu' 'CFLAGS=-m32' 'CXXFLAGS=-m32' 'LDFLAGS=-m32'
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler works... no
configure: error: in `/home/thierry/Documents/freetype-2.4.12/builds/unix':
configure: error: C compiler cannot create executables
See `config.log' for more details
builds/unix/detect.mk:86: recipe for target 'setup' failed
make: *** [setup] Error 77
See attached for the log file
QUESTION :
1] What is a method to install modelsim_ase on Fedora 21 ?
2] Where can I get modelsim_ase for recent Linux ?
Best regards
