16 years agomixed 3.3V and 1.2V I/O interface
This is probably simple to answer: I am working with the CycloneIII, It is interfacing a microcontroller with 3.3V on one side, and also has interfaces of 1.2V digital devices. I supply the I/O banks with 1.2V or 3.3V on its VCCIO pins to support the different interface voltage levels. My question is : is that enough, or should i use the VREFB pins as well? Thanks in advance' Gabi4 Replies
Thank you !
Here is the guidance from the Cyclone III pin connection guidelines:
--- Quote Start --- Input reference voltage for each I/O bank. If a bank uses a voltage- referenced I/O standard for input operation, then these pins are used as the voltage-reference pins for the bank. If voltage reference I/O standards are not used in the bank, the VREF pins are available as user I/O pins. If VREF pins are not used, the designer should connect them to either the VCCIO of the I/O bank in which the pin resides or GND. Decoupling depends on the design decoupling requirements of the specific board. See Note 5. When VREF pins are used as I/O, they have higher capacitance than regular I/O pins which will slow the edge rates and affect I/O timing. --- Quote End --- If you are not going to use them as I/O pins, connect them to ground. However, make sure you don't accidentally configure them as I/O in your FPGA design and try to drive a logic high signal out on them. Jake - Altera_Forum
I've got it...Thank you!
I will connect those VREFB pins to GND, is that okay ? Thanks in advance' Gabi - Altera_Forum
No that's all you have to do. Vref pins are only used for I/O standards that require a reference voltage for input. SSTL is one such example. DDR memory interfaces use the reference voltage.
The real answer to your question lies in the Cyclone III handbook. See Table 6-4 on page 6-12 of the following document: http://www.altera.com/literature/hb/cyc3/cyc3_ciii5v1_02.pdf If it doesn't say "Voltage-referenced" in the Type column, you don't need a reference voltage. More details can be found in the Cylcone III datasheet: http://www.altera.com/literature/hb/cyc3/cyc3_ciii52001.pdf Jake
