Missing AC characteristsics in A5E data sheet !
With reference to this link :
where are these numbers ?
I would like the switching performance of the 1.8V Agilex5 I/O.
Is there any AC/DC performance specification anywhere for the HVIO ?
-glen
- Farabi_Altera
Hi Glen, the page rendering issue you're seeing is likely a JavaScript/session problem with the docs portal — the switching characteristics section definitely has content. Try a hard refresh (Ctrl+F5) or open the page in a private/incognito browser window. If the docs site is still not rendering the tables, the PDF version of the data sheet (downloadable from the same page) is the reliable fallback.
That said, here is what the verified specs show for Agilex 5 1.8 V I/O performance:
HVIO banks — 1.8 V operation
- HVIO at 1.8 V single-ended (LVCMOS/LVTTL): 0.250 Gbps (125 MHz DDR). RGMII is supported at this voltage level. Agilex™ 5 FPGAs and SoCs Device Overview
- HVIO supports 1.8 V, 2.5 V, and 3.3 V single-ended, non-voltage-referenced, JEDEC-compliant I/O standards. General-Purpose I/O User Guide Agilex™ 5 FPGAs and SoCs
- HVIO provides up to 40 pins per block and up to 20 pins per bank. Device Design Guidelines: Agilex™ 5 FPGAs and SoCs
HPS I/O and SDM I/O — also 1.8 V
- HPS I/O operates at 1.8 V single-ended, non-voltage-referenced. General-Purpose I/O User Guide Agilex™ 5 FPGAs and SoCs
- SDM I/O likewise operates at 1.8 V single-ended, non-voltage-referenced. General-Purpose I/O User Guide Agilex™ 5 FPGAs and SoCs
HSIO banks — not 1.8 V
Note that the HSIO banks do not support 1.8 V. HSIO LVCMOS is specified for 1.0 V, 1.05 V, 1.1 V, and 1.2 V single-ended only. Agilex™ 5 FPGAs and SoCs Device Overview If you need higher-speed I/O performance beyond the 125 MHz DDR of HVIO, the HSIO banks at 1.0–1.3 V are the path — TDS on HSIO supports up to 1.6 Gbps at 1.3 V and works with the LVDS SERDES IP. Agilex™ 5 FPGAs and SoCs Device Overview
The detailed setup/hold, tco, and propagation-delay tables for the HVIO buffers are in the "Periphery Performance Specifications" section of the data sheet, which covers periphery performance, LVDS SERDES, and external memory interface specifications. Agilex® 5 FPGAs and SoCs Device Data Sheet The PDF download from the same docs.altera.com URL should render all of those tables correctly if the web view is giving you trouble.
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
