14 years agomismatching connect
Hi every one Im working with design dds i built my phase acumulator using and create block for specifc phase accumulator design with (23..80 output .I connect the phase accum (PA) to RAM with in...
14 years agoOk, I'll guess ...
You have a phase accumulator with PWIDTH bits, you have a RAM with AWIDTH bits, and AWIDTH < PWIDTH ... so how do you connect these? You need to think of both as complete rotations around an imaginary phasor (circle). Both have to go a complete 360-degrees around the circle as the number goes from 0 to 2**PWIDTH-1 or 2**AWIDTH-1. The answer is, the MSBs need to be connected together, i.e., ram <= acc(PWIDTH-1 downto PWIDTH-AWIDTH); where ram(AWIDTH-1 downto 0), and you've connected the AWIDTH MSBs of the accumulator to the RAM. Or something like that anyway ... :) There's some stuff on NCOs in here: http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100paper_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-100paper_hawkins.pdf) A nice way to interpret the accumulator, is that it is a fixed-point number in fractional integer format, with the whole part being the address into the RAM. Cheers, Dave
