Sanjeev1
1 year agoMini LVDS operating distance
Hi, We are having DK-SOC-1SSX-H-D development kit with us. Which supports Mini-LVDS interface. Can someone let us know, using this technology what is the maximum distance can be supported between dr...
AqidAyman_Altera
1 year agoHi,
Do you have any more questions on this?
- FvM1 year ago
there's no specific limitation "by protocol". You'll however experience data rate depending signal attenuation and waveform distortion. Presuming impedance matched and correctly terminated differential cable, you can achieve 10 m distance for 100 to 200 MBPS. The other possible limitation is common mode noise and voltage offset in case of inter-instrument communication. Consider that standard network interfaces like Ethernet use transformer coupling to get rid of common noise.- Sanjeev11 year ago
Thanks for the details.
Sanjeev
