14 years agomigration from EP3SL150F1152C2 to EP3SL200F1152C2
Hello, I need to migrate from EP3SL150F1152C2 to EP3SL200F1152C2 and I am using the Stratix III development kit board, I need to make a schematic/board modification or can I use the same schema...
14 years agoSome I/O pins could be different. In your Quartus project, you can define the second FPGA as a migration device and run an I/O check to be sure you don't need to move any I/O pin. Have also a look at the pin-out file from the Fitter report and compare with your schematic.
