19 years agoMigrating devices - Power and Ground on I/Os?
When using device migration, I find that I/O pins on some devices are supposed to be power or ground on other devices. Is it okay to connect I/O pins to power or ground on my board?
19 years agoBy the way , I have a question about "Unused Pins Driving Ground / VCC"
When we design DDRII interface using IO Standard of SSTL18 Class I In order to reduce SSN , I have tried to put all the unused pins to be user-assigned Outputs driving Ground (In experimental result , Ground Bounce seems more significant then VCC sag) And then on the PCB , these unused pins are connected to Ground However , Fitter gives a error message that It violates the VREF rules (I guess Quartus treats the pins as output although they are driving ground directly) And then finally , I choose not to place Pins in design file for these unused pins In Assignment --> Device --> Device and Pin Options --> Unused Pins --> As output driving Gorund Comparing these two approach , do they give the same result ? I mean , do they help in reducing SSN in same extent ? Thanks
