11 years agoMigrate to new Spansion SPI NOR Flash for AS configuration
Hi, I've found Spansion app note which give S25FL064P replacement part for EPCS64. Unfortunatly, this device doesn't exist in SO8 (208mil) and i wan't to "size upgrade" a EPCS16 device in SO8 ...
11 years agoMy Cyclone IV board works with the S25FL164K as the serial configuration device. :)
A few other observations: Setting or clearing any combination of the 'Disable EPCS ID check' & 'Disable AS mode CONF_DONE_error check' radio buttons (available in Q13.1) doesn't affect it - it works regardless of these settings. So, it's likely to work with Q14.0 too. Furthermore, generating a .jic file for use with an EPCS16 continues to work too. Cheers, Alex
