16 years agoMemory to Device DMA transfer
Hi, I am working on a byte transfer from SDRAM to a register of my custom hardware. I have set the byte transfer enable and wcon for byte transfers and write to a constant address. But, I see t...
16 years agoHi,
I tried all possible options and was able to narrow down on the problem. If I enable burst transfers in SOPC, I am getting this problem and if I don't enable it is working fine. Can you explain this? Why does the DMA write only a byte of the word if the burst transfer is enable? Thanks.
