16 years agoMemory to Device DMA transfer
Hi, I am working on a byte transfer from SDRAM to a register of my custom hardware. I have set the byte transfer enable and wcon for byte transfers and write to a constant address. But, I see t...
16 years agoHi,
So your control register before starting the transfer by setting the GO-bit looks like that? BIT0(BYTE) | BIT4(I_EN) | BIT7(LEEN) | BIT9(WCON) If so, I would say you'v done it right and I have no idea what is wrong..... EDIT: Just to be sure. In sopc the DMA is configured to perform byte transfers?
