14 years agoMemory array to pio using DMA (Video)
Hi, all! I need to create a videosystem with soft processing on Nios II. Hardware: Camera MT9P001 (TRDB-D5M), Board DE2-115 (Cyclone 4, Video DAC ADV7123, SRAM 2 MB). System structure: C...
14 years agoSome DMAs support streaming directly so sometimes you don't even need the FIFO since DMAs have FIFOs inside them. Using SOPC Builder you still need a dummy component in order to get the FIFO/DMA interface up to the top using a conduit. If you used Qsys you could export the ST port of the DMA directly and wire it up to your DAC.
By the way I forgot to copy the link to the design I was talking about... http://www.alterawiki.com/wiki/modular_sgdma_video_frame_buffer
