13 years agomegafunctions problems
:confused: Hi there, i starting my first project with the SOPC Builder using an NIOSII. After starting the Quartus Programmer I got these message: "example.sof contains on or more time...
12 years agoHere are ALL the warnings (yellow triangle with ! in it) messages from the build log (Message tab). Nothing looks wrong here to me ...
Warning (20028): Parallel compilation is not licensed and has been disabled Warning (12020): Port "jdo" on the entity instantiation of "the_first_nios2_system_cpu_nios2_oci_itrace" is connected to a signal of width 38. The formal width of the signal in the module is 16. The extra bits will be ignored. Warning (12188): OpenCore Plus Hardware Evaluation feature is turned on for the following cores ---Warning (12190): "Nios II Processor (6AF7_00A2)" will use the OpenCore Plus Hardware Evaluation feature Warning (265072): Messages from megafunction that supports OpenCore Plus feature ---Warning (265073): Messages from megafunction that supports OpenCore Plus feature Nios II Processor ------Warning (265074): The reset input will be asserted when the evaluation time expires Warning (265069): Megafunction that supports OpenCore Plus feature will stop functioning in 1 hour after device is programmed Warning (12241): 2 hierarchies have connectivity warnings - see the Connectivity Checks report folder Warning (13024): Output pins are stuck at VCC or GND ---Warning (13410): Pin "sld_hub:auto_hub|receive[0][0]" is stuck at GND
