13 years agomegafunctions problems
:confused: Hi there, i starting my first project with the SOPC Builder using an NIOSII. After starting the Quartus Programmer I got these message: "example.sof contains on or more time...
13 years agoIf you are using SOPC Builder then a license is required for the Nios II, however, when you're using QSYS the Nios II/e is free but you need a license for Nios II/s and Nios II/f.
Are there any other IP cores in your project that might be causing this besides the Nios? The error messages seem to indicate three different products that you need licenses for. I believe vendor "6AF7" is Altera so it it sounds like an Altera IP Core.
