11 years agomegacore fft sumulation help
Hello to all. i want simulate the fft megacore with modelsim. I use the fft_tb.v generated from megacore. the output alwas stay at fixed value (see picture). i do not understand.... ...
11 years ago --- Quote Start --- I get the same result as the last pic you posted (running script only). Only bottom bit of the output active all others tri-state :-(. Very odd! --- Quote End --- Yes.. rtl simulation have outputs ok.. gate simulation have output high impedance :(
