12 years agomeeting timing requirement in quartus without hard ip license for quartus synthesis
For a project we required ip of spi4.2. but before buying it from altera we created some interface for it and tried to synthesize it with the sdc we have made. my question is is it possible that due to non availability of licese of that ip their is some timing requirement no meeting in that interface block of spi...kindly help
If its your own IP, you will need to make your own timing requirements.
--- Quote Start --- If its your own IP, you will need to make your own timing requirements. --- Quote End --- hey tricky ..i wanted to if i use the altera ip and use it without license ..then can it meet sta even without license for that ip because i cant generate rbf untill i have license for ip...what i got is only .sof file.
