19 years agoMeasuring SSN
Hi, i have seen people trying to measure SSN with the toggling aggressors on the FPGA floating (not connected to anywhere). How accurate is that compared to aggressors with load?
19 years agoYou must have load caps in a SSO measurement. the discharge from the load capacitors flowing back into the device are what cause the ground bounce event. The larger the load the larger the bounce event. You need to choose the load that best represents what you expect as trace and load capacitance in your application.
