12 years agoMCP2515 CAN controller using SPI interface
Hello everybody, This is my first post on the Altera Forums, and i have to say it's been quite helpfull to me the last few months, so thanks for that. This is my situation: I need to ...
11 years ago --- Quote Start --- Hello everybody, This is my first post on the Altera Forums, and i have to say it's been quite helpfull to me the last few months, so thanks for that. This is my situation: I need to send and recieve messages via the CAN interface with the MCP2515 chip. I've done the Quartus block diagram which includes the NIOS 2 processor, an SDRAM from the Deo-Nano board, and an SPI interface with which to communicate with the CAN controller, and everything works perfectly (no timing errors or nothing). So basically, i just need help with the C coding using alt_avalon_spi_command. i'll just show my code and you give oppinions if you'd like.
void RESET ()
unsigned char command;
command=0x30;
alt_avalon_spi_command(SPI_BASE,0,1,command,0,NULL,0);
unsigned char READ_RX_BUFF (unsigned char reg)
//00 RXB0SIDH
//01 RXB0D0
//02 RXB1SIDH
//03 RXB0D1
unsigned char rdata,rdata1,command;
unsigned char data_out;
unsigned int i;
command=(1<<7) | (1<<4) | (reg<<1);
printf("\n%d ",command);
for (i=0; i<8; i++)
rdata=0 ;
rdata1=0 ;
data_out=0;
if ((reg==0) || (reg==2))
alt_avalon_spi_command(SPI_BASE,0,1,command,5,rdata,0);
for (i=0; i<5; i++)
data_out= rdata ;
printf("%x ",data_out);
if ((reg==1) || (reg==3))
alt_avalon_spi_command(SPI_BASE,0,1,command,8,rdata1,0);
for (i=0; i<8; i++)
data_out= rdata1 ;
return *data_out;
void SPI_WRITE(alt_u8 adress, alt_u8 message)
command=0x02;
alt_avalon_spi_command(SPI_BASE,0,1,&adress,0,NULL,0);
alt_avalon_spi_command(SPI_BASE,0,1,&message,0,NULL,0);
unsigned char SPI_READ(alt_u8 adress)
unsigned char read;
command=0x03;
read=0;
alt_avalon_spi_command(SPI_BASE,0,1,&adress,1,read,0);
data_out=read;
return data_out;
void SPI_LOAD_TX(long int message, alt_u8 reg)
//reg 0x0 TXB0SIDH
//reg 0x1 TXB0D0
//reg 0x2 TXB1SIDH
//reg 0x3 TXB0D1
//reg 0x4 TXB2SIDH
//reg 0x5 TXB1D2
unsigned char message1,command; ////read byte 0x04
int i;
command=(1<<6)|reg;
if ((reg==0x00) || (reg==0x02) || (reg==0x4))
for (i=0; i<5; i++)
{ message=message>>(i*8);
message1=message & 0xff;
alt_avalon_spi_command(SPI_BASE,0,1,message1,0,NULL,0);
if ((reg==0x01) || (reg==0x03) || (reg==0x5))
for (i=0; i<8; i++)
void RTS(alt_u8 reg)
//reg 0x00 T1
//reg 0x02 T2
//reg 0x04 T3
command=(0x01<<7) | reg;
void BIT_MODIFY(alt_u8 adress, alt_u8 mask, alt_u8 data)
command=0x05;
alt_avalon_spi_command(SPI_BASE,0,1,&mask,0,NULL,0);
alt_avalon_spi_command(SPI_BASE,0,1,&data,0,NULL,0);
void SPEED_RATE(alt_u8 rate)
if (rate==10)
BIT_MODIFY(CNF1,0xff,0x31); //CNF1
BIT_MODIFY(CNF2,0xff,0xb8); //CNF2
BIT_MODIFY(CNF3,0xff,0x05); //CNF3
if (rate==20)
BIT_MODIFY(CNF1,0xff,0x18); //CNF1
if (rate==50)
BIT_MODIFY(CNF1,0xff,0x09); //CNF1
if (rate==100)
BIT_MODIFY(CNF1,0xff,0x04); //CNF1
if (rate==125)
BIT_MODIFY(CNF1,0xff,0x03); //CNF1
if (rate==250)
BIT_MODIFY(CNF1,0xff,0x01); //CNF1
if (rate==500)
BIT_MODIFY(CNF1,0xff,0x00); //CNF1
void CONFIG_STATE(char state)
if (state==1)
//CANCTRL status config
BIT_MODIFY(CANCTRL,0xff,MODE_CONFIG); //configuration mode
SPEED_RATE(100); //speed rate 100kbps
BIT_MODIFY(0x2b,0xff,0x00); //CANINTE clear
BIT_MODIFY(0x2c,0xff,0x00); //CANINTF clear
//BFPCTRL set
BIT_MODIFY(0x0c,0xff,0x0f); // RXnBF set as interrupt pin(0x0f)
BIT_MODIFY(RXB0CTRL,0xff,0x60); // Write to RXB0CTRL and set masks and filters off
BIT_MODIFY(RXB1CTRL,0xff,0x60); // Write to RXB1CTRL and set masks and filters off
//RX BUFFER 0
BIT_MODIFY(RXM0SIDH,0xff,0x00); // RXM0SIDH clear
BIT_MODIFY(RXM0SIDL,0xff,0x00); // RXM0SIDL clear
BIT_MODIFY(RXM0EID8,0xff,0x00); // RXM0EID8 clear
BIT_MODIFY(RXM0EID0,0xff,0x00); // RXM0EID0 clear
//RX BUFFER 1
BIT_MODIFY(RXM1SIDH,0xff,0x00); // RXM1SIDH clear
BIT_MODIFY(RXM1SIDL,0xff,0x00); // RXM1SIDL clear
BIT_MODIFY(RXM1EID8,0xff,0x00); // RXM1EID8 clear
BIT_MODIFY(RXM1EID0,0xff,0x00); // RXM1EID0 clear
//TXRTSCTRL set
BIT_MODIFY(0x0d,0xff,0x01); // request to send from txb0 (0x01)
BIT_MODIFY(0x2D,0xff,0x00); // clear EFLG
if (state==2)
BIT_MODIFY(CANCTRL,0xff,MODE_LISTEN); //listen mode
if (state==3)
BIT_MODIFY(CANCTRL,0xff,MODE_LOOPBACK); //loopback mode
if (state==4)
BIT_MODIFY(CANCTRL,0xff,MODE_SLEEP); //sleeep mode
if (state==5)
BIT_MODIFY(CANCTRL,0xff,MODE_NORMAL); //normal mode
int main()
{unsigned long int delay;
unsigned char radu,radu1;
RESET();
CONFIG_STATE(1);
CONFIG_STATE(5);
while(1)
{delay=0;
while (delay<200000)
{delay++;}
y=READ_RX_BUFF(1);
SPI_WRITE(0x61,0x05);
x=SPI_READ(0x61);
printf(" %d %d ",y,x);
of course this includessome Macros declarations in a separate file. So the problem is this. What am I doing wrong :) thanks if you read, and sorry for the bad english. --- Quote End --- Hi, Pallys, Have you found an answer? I'm currently working on the same connection (Nios/MCP2515). I've learned from the datasheet that you cannot use BIT_MODIFY on all registers. You need to do an SPI_WRITE instead. Also, the minimum registers you need to write to are TXBnSIDH, TXBnSIDL and TXBnDLC before performing an RTS. From your comments, I can see you do not consider the last two, although you consider the data register TXBnDm. I think that before you send any data using TXBnDm you should, first, send only a message with headers, which will require less SPI tranmissions, thus rendering the process less prone to errors. Well, let me know if you could make it work. Thanks, Lucas.
