May I Use MIPI Strandard IO (HS/LP Compatible IO) Without Using Altera MIPI-DPHY IP
Hi
We have not hear from you and this Case is idling. It is not recommended to idle for too long.
Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Altera experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me via this forum page of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Altera
p/s: If any answer from the community or Altera Support is helpful, please feel free to give the best answer or rate 9/10 survey.
- johnson0371 year ago
Hi Wincent :
Recently, I am on my travel vacation in Japan.
So, I Can't reply your message quickly.
thanks for your reply.
From your answer,
It seems that the agilex5 FPGA MIPI IO can not use alone (must use with Agilex5 MIPI D_Phy)
because "There is a block who handles the external incoming data deserialization
with its clocking for both HS and LP modes"
Is my understanding about this answer correct !?...
thank you~
