johnson037
1 year agoMay I Use MIPI Strandard IO (HS/LP Compatible IO) Without Using Altera MIPI-DPHY IP
Hi : From the Altera agilex 5 MIPI D-Phy IP User Guide, We Know that We can use MIPI Standard IO (HS/LP Compatable IO) By Using Altera MIPI DPhy IP. ...
Wincent_Altera
1 year agoHi,
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
Else I would like to have your permission to close this forum ticket. Nevertheless, you can still response to the forum and I will be available to assist you.
Wincent_Altera
p/s: If any answer from the community or Altera Support is helpful, please feel free to give the best answer or rate 9/10 survey.
