12 years agoMAXV maximum current per bank
Hi, What's the maximum current per bank in 5M570ZT144C? I need to drive 56 leds with 5mA (280mA). Is it possible? VDDIO = 3V3 Thanks. Bruno Bernardi
12 years ago --- Quote Start --- Didn't you find it? It's 170 mA if I remember right. --- Quote End --- The AN286 is not about the MAX V only MAX and MAX II. 170mA per pin (GND) or bank? If 170mA per pin. Would be 850mA per bank? according to AN286: "For example, the EPM240 device has six GNDIO pads, which provide six I/O regions that can sink up to 130 mΑ. If you need to sink 15 mA for the outputs, you can have eight outputs per region. With the six regions of I/O between GNDIO pads, there are 48 possible outputs, each sinking 15 mA."
