11 years agoMAXV - User Flash Memory
Hello, I would have one question related to user Flash Memory programming (UFM) on MAXV. In the data sheet, there is written: "The targeted location in the UFM block that will be written...
11 years agosynchronous,
MAXV UFM is a flash memory. So, it can retain what you what to store on it during no power. One difference is the number of write cycles which is limitted to 100 for the industrial range and 1000 write cycles for the commercial range. This is the only limiting factor. So, use the MAXV UFM to store configuration parameters that you do not think to update so often. Hope this helps. Fabe
