11 years agoMAXV - User Flash Memory
Hello, I would have one question related to user Flash Memory programming (UFM) on MAXV. In the data sheet, there is written: "The targeted location in the UFM block that will be written...
11 years agoHi Fabe,
Thanks for the reply. I don't think POF file allow CPLD to retain configuration, once there is no power. Typically SOF file, which is written to a flash device (on board EEPROM) retains the device configuration in case of power disruption. As per AN-631 "you can use the ufm block to replace on-board flash and eeprom memory devices to store assp or processor configuration bits" I don't think your ans 1) provides this solution. Did you permanently configure your Max V, using UFM? If so, then please mention the key steps. Thanks again,
