15 years ago
max+plus2 advanced synthesis error message
Dear Forum member:
I want to ask what means the error message "Internal Error: Sub-system: SUTIL, File: sutil_dump_max.cpp, Line: 4904".
The Advanced Synthesis version is 1.01.
Using device is EPM7160ELC84-*.
Toru.
    The code compiles correctly in Quartus. I don't see a problem, that can be expected to cause problems in max+plus2.
    Apart from this point, som design details seems questionable in the code:
    - why are counting input events mutual exlusive (using else if).
    - do you intend to count 0 to 10, as the code does, or 0 to 9?
    - do you want to count negative edges or sample low state?
    - assuming the inputs are unrelated to CLK, synchronizing would be required to avoid wrong counting
    Dear Dave,
    Thank you for your re-reply.
    --- Quote Start ---
    There is no hope in getting help with an error message without seeing code, and even then, the error indicates a problem internal to MAX+Plus II.
    --- Quote End ---
    Here is the code which is a decimal counter and a 7-segment-LED-display by verilog-HDL.
    Using crystal oscillator is 27MHz.
    When negative pulse received, 7-segment-LED displays received time(s).
    module dsk_counter3(CLK, PS1, PS2, FAN, RESET, SEG7_OE_B, SEG7);
    	input CLK, PS1, PS2, FAN, RESET;
    	output  SEG7_OE_B;
    	output reg  SEG7;
    	reg  count_2ms;
    	reg cnt_2ms;
    	wire pulse_2ms;
    	reg  PS1_cnt;
    	reg  PS2_cnt;
    	reg  FAN_cnt;
    	reg  seg_PS1;
    	reg  seg_PS2;
    	reg  seg_FAN;
    	reg  SEG_OE_cnt;
    	wire  SEG_OE_digit;
    	reg  SEGEN_O;
    	always @(posedge CLK or negedge RESET)
    	begin
    		if(!RESET)
    		begin
    			cnt_2ms <= 1'b0;
    			count_2ms <= 16'h0;
    		end else
    		begin
    			if(count_2ms == 16'hD2F0)		// (27MHz / 1000 * 2 = 2ms(54,000count))
    			begin
    				cnt_2ms <= 1'b1;
    				count_2ms <= 16'h0;
    			end else
    			begin
    				cnt_2ms <= 1'b0;
    				count_2ms <= count_2ms + 16'h1;
    			end
    		end
    	end
    	assign pulse_2ms = cnt_2ms;
    	begin
    		if(!RESET)
    		begin
    			PS1_cnt <= 4'b0000;
    			PS2_cnt <= 4'b0000;
    			FAN_cnt <= 4'b0000;
     		end else
    		begin
    			if(pulse_2ms == 1'b1)
    			begin
    				if(!PS1)
    				begin
    					if(PS1_cnt == 4'b1010) PS1_cnt <= 4'b0000;
    					PS1_cnt <= PS1_cnt + 4'b1;
    				end else if(!PS2)
    				begin
    					if(PS2_cnt == 4'b1010) PS2_cnt <= 4'b0000;
    					PS2_cnt <= PS2_cnt + 4'b1;
    				end else if(!FAN)
    				begin
    					if(FAN_cnt == 4'b1010) FAN_cnt <= 4'b0000;
    					FAN_cnt <= FAN_cnt + 4'b1;
    				end
    			end
    		end
    	end
    	always @*
    	begin
    		case(PS1_cnt)
    			4'b0000 : seg_PS1 <= 8'b00001010; // A-F-E-D-DotPoint-C-G-B
    			4'b0001 : seg_PS1 <= 8'b11111010;
    			4'b0010 : seg_PS1 <= 8'b01001100;
    			4'b0011 : seg_PS1 <= 8'b01101000;
    			4'b0100 : seg_PS1 <= 8'b10111000;
    			4'b0101 : seg_PS1 <= 8'b00101001;
    			4'b0110 : seg_PS1 <= 8'b00001001;
    			4'b0111 : seg_PS1 <= 8'b00111010;
    			4'b1000 : seg_PS1 <= 8'b00001000;
    			4'b1001 : seg_PS1 <= 8'b00101000;
    			default : seg_PS1 <= 8'b11111111;
    		endcase
    		case(PS2_cnt)
    			4'b0000 : seg_PS2 <= 8'b00001010; // A-F-E-D-DotPoint-C-G-B
    			4'b0001 : seg_PS2 <= 8'b11111010;
    			4'b0010 : seg_PS2 <= 8'b01001100;
    			4'b0011 : seg_PS2 <= 8'b01101000;
    			4'b0100 : seg_PS2 <= 8'b10111000;
    			4'b0101 : seg_PS2 <= 8'b00101001;
    			4'b0110 : seg_PS2 <= 8'b00001001;
    			4'b0111 : seg_PS2 <= 8'b00111010;
    			4'b1000 : seg_PS2 <= 8'b00001000;
    			4'b1001 : seg_PS2 <= 8'b00101000;
    			default : seg_PS2 <= 8'b11111111;
    		endcase
    		case(FAN_cnt)
    			4'b0000 : seg_FAN <= 8'b00001010; // A-F-E-D-DotPoint-C-G-B
    			4'b0001 : seg_FAN <= 8'b11111010;
    			4'b0010 : seg_FAN <= 8'b01001100;
    			4'b0011 : seg_FAN <= 8'b01101000;
    			4'b0100 : seg_FAN <= 8'b10111000;
    			4'b0101 : seg_FAN <= 8'b00101001;
    			4'b0110 : seg_FAN <= 8'b00001001;
    			4'b0111 : seg_FAN <= 8'b00111010;
    			4'b1000 : seg_FAN <= 8'b00001000;
    			4'b1001 : seg_FAN <= 8'b00101000;
    			default : seg_FAN <= 8'b11111111;
    		endcase
    	end
    	always @(posedge CLK)
    	begin
    		SEG_OE_cnt <= SEG_OE_cnt + 32'b1;
    	end
    	assign SEG_OE_digit = SEG_OE_cnt;
    	begin
    		case(SEG_OE_digit)
    			2'b00 : SEG7 <= seg_PS1;
    			2'b01 : SEG7 <= seg_PS2;
    			2'b10 : SEG7 <= seg_FAN;
    			default : SEG7 <= 8'b11111111;
    		endcase
    	end
    	begin
    		case(SEG_OE_digit)
    			2'b00 : SEGEN_O <= 3'b110;
    			2'b01 : SEGEN_O <= 3'b101;
    			2'b10 : SEGEN_O <= 3'b011;
    			default : SEGEN_O <= 3'b111;
    		endcase
    	end
    	assign SEG7_OE_B = SEGEN_O;
    endmodule
    I do not try to synthesize this code by other tools yet.
    I will be back after I found anything.
    Toru.
    Hi Toru,
    --- Quote Start ---
    But Quartus does not support devices MAX7000(E), and I only have devices (EPM7032, EPM7128, EPM7160, etc), therefore, I just have to use Max+Plus II.
    --- Quote End ---
    I just checked Quartus 9.0SP2 and it supports MAX7000AE, MAX7000B, and MAX7000S, so it looks like you are right, there is no MAX7000(E) support.
    --- Quote Start ---
    So, please let me know anything about the error message.
    --- Quote End ---
    However, if the error is being caused by invalid syntax, you could try compiling your code with a newer version of Quartus (targeting a newer MAX7000 device), or with the Modelsim simulator, and then once you are convinced the code (and synthesized logic) is correct, go back to target the MAX7000E in MAX+Plus II.
    Cheers,
    Dave
    Dear Tricky,
    Thank you for your reply.
    I will try to check any more.
    Toru.
    The error sounds like an internal bug
    This bug wont be fixed by altera
    good luck finding a solution without an update.
    Dear Dave,
    --- Quote Start ---
    Max+Plus II is ancient. You should update to use Quartus 11.
    --- Quote End ---
    I understand that Max+Plus II is ancient. But Quartus does not support devices MAX7000(E), and I only have devices (EPM7032, EPM7128, EPM7160, etc), therefore, I just have to use Max+Plus II.
    Toru.
    Hi Toru,
    If you have to build for FLEX10K, ACEX series devices, then use Quartus 9.0SP2. If you are using Windows 7, then I would recommend installing the older version of Quartus into a virtual machine running Windows XP (I haven't tried it under Windows 7).
    Cheers,
    Dave
