15 years agomax+plus2 advanced synthesis error message
Dear Forum member: I want to ask what means the error message "Internal Error: Sub-system: SUTIL, File: sutil_dump_max.cpp, Line: 4904". The Advanced Synthesis version is 1.01. Using dev...
15 years agoDear Dave,
Thank you for your re-reply. --- Quote Start --- There is no hope in getting help with an error message without seeing code, and even then, the error indicates a problem internal to MAX+Plus II. --- Quote End --- Here is the code which is a decimal counter and a 7-segment-LED-display by verilog-HDL. Using crystal oscillator is 27MHz. When negative pulse received, 7-segment-LED displays received time(s).module dsk_counter3(CLK, PS1, PS2, FAN, RESET, SEG7_OE_B, SEG7);
input CLK, PS1, PS2, FAN, RESET;
output SEG7_OE_B;
output reg SEG7;
reg count_2ms;
reg cnt_2ms;
wire pulse_2ms;
reg PS1_cnt;
reg PS2_cnt;
reg FAN_cnt;
reg seg_PS1;
reg seg_PS2;
reg seg_FAN;
reg SEG_OE_cnt;
wire SEG_OE_digit;
reg SEGEN_O;
always @(posedge CLK or negedge RESET)
begin
if(!RESET)
begin
cnt_2ms <= 1'b0;
count_2ms <= 16'h0;
end else
begin
if(count_2ms == 16'hD2F0) // (27MHz / 1000 * 2 = 2ms(54,000count))
begin
cnt_2ms <= 1'b1;
count_2ms <= 16'h0;
end else
begin
cnt_2ms <= 1'b0;
count_2ms <= count_2ms + 16'h1;
end
end
end
assign pulse_2ms = cnt_2ms;
begin
if(!RESET)
begin
PS1_cnt <= 4'b0000;
PS2_cnt <= 4'b0000;
FAN_cnt <= 4'b0000;
end else
begin
if(pulse_2ms == 1'b1)
begin
if(!PS1)
begin
if(PS1_cnt == 4'b1010) PS1_cnt <= 4'b0000;
PS1_cnt <= PS1_cnt + 4'b1;
end else if(!PS2)
begin
if(PS2_cnt == 4'b1010) PS2_cnt <= 4'b0000;
PS2_cnt <= PS2_cnt + 4'b1;
end else if(!FAN)
begin
if(FAN_cnt == 4'b1010) FAN_cnt <= 4'b0000;
FAN_cnt <= FAN_cnt + 4'b1;
end
end
end
end
always @*
begin
case(PS1_cnt)
4'b0000 : seg_PS1 <= 8'b00001010; // A-F-E-D-DotPoint-C-G-B
4'b0001 : seg_PS1 <= 8'b11111010;
4'b0010 : seg_PS1 <= 8'b01001100;
4'b0011 : seg_PS1 <= 8'b01101000;
4'b0100 : seg_PS1 <= 8'b10111000;
4'b0101 : seg_PS1 <= 8'b00101001;
4'b0110 : seg_PS1 <= 8'b00001001;
4'b0111 : seg_PS1 <= 8'b00111010;
4'b1000 : seg_PS1 <= 8'b00001000;
4'b1001 : seg_PS1 <= 8'b00101000;
default : seg_PS1 <= 8'b11111111;
endcase
case(PS2_cnt)
4'b0000 : seg_PS2 <= 8'b00001010; // A-F-E-D-DotPoint-C-G-B
4'b0001 : seg_PS2 <= 8'b11111010;
4'b0010 : seg_PS2 <= 8'b01001100;
4'b0011 : seg_PS2 <= 8'b01101000;
4'b0100 : seg_PS2 <= 8'b10111000;
4'b0101 : seg_PS2 <= 8'b00101001;
4'b0110 : seg_PS2 <= 8'b00001001;
4'b0111 : seg_PS2 <= 8'b00111010;
4'b1000 : seg_PS2 <= 8'b00001000;
4'b1001 : seg_PS2 <= 8'b00101000;
default : seg_PS2 <= 8'b11111111;
endcase
case(FAN_cnt)
4'b0000 : seg_FAN <= 8'b00001010; // A-F-E-D-DotPoint-C-G-B
4'b0001 : seg_FAN <= 8'b11111010;
4'b0010 : seg_FAN <= 8'b01001100;
4'b0011 : seg_FAN <= 8'b01101000;
4'b0100 : seg_FAN <= 8'b10111000;
4'b0101 : seg_FAN <= 8'b00101001;
4'b0110 : seg_FAN <= 8'b00001001;
4'b0111 : seg_FAN <= 8'b00111010;
4'b1000 : seg_FAN <= 8'b00001000;
4'b1001 : seg_FAN <= 8'b00101000;
default : seg_FAN <= 8'b11111111;
endcase
end
always @(posedge CLK)
begin
SEG_OE_cnt <= SEG_OE_cnt + 32'b1;
end
assign SEG_OE_digit = SEG_OE_cnt;
begin
case(SEG_OE_digit)
2'b00 : SEG7 <= seg_PS1;
2'b01 : SEG7 <= seg_PS2;
2'b10 : SEG7 <= seg_FAN;
default : SEG7 <= 8'b11111111;
endcase
end
begin
case(SEG_OE_digit)
2'b00 : SEGEN_O <= 3'b110;
2'b01 : SEGEN_O <= 3'b101;
2'b10 : SEGEN_O <= 3'b011;
default : SEGEN_O <= 3'b111;
endcase
end
assign SEG7_OE_B = SEGEN_O;
endmodule I do not try to synthesize this code by other tools yet. I will be back after I found anything. Regards, Toru.
