8 years agoMaximum inputs per LAB
Can't find this documented anywhere. Is there a cap on the total number of signals that can be routed into a single LAB? Take Cyclone V, to be specific. From the datasheets, I was under the imp...
8 years agoRegional clocks are an interesting idea, I haven't even considered their effect ... I really don't want to put in clock-crossing logic at this point, but it's something to keep in mind in future.
The optimization mode was "Power - High Effort" (but results are more or less the same in "Performance - High Effort".) I am meeting hold timing in all timing models. Going to rerun in "Performance" with hold timing option turned off - back to you in an hour. The code for this particular path was effectively out[57] <= in[56] ^ in[120] ^ in[312] ^ in[472];
