RRReed
2 years agoMaximum external DDR4 memory capacity supported by Agilex 7 M- and I-Series?
I'm having trouble finding the answer to a seemingly simple question: what is the greatest amount of external DDR4 memory (components, not DIMMs) an Agilex 7 M- or I-Series FPGA can address or suppor...
- 2 years ago
The DDR4 component support in Agilex M - Series FPGA has slightly lower interface width than Agilex F/I -Series.
Those this will limit the memory density to 16GB.
Based on used cases, the HBM2e has memory capacity of 32GB per channel while there are 32 channels.
The DDR5 memory capacity can go up to 32GB as well.
You may refer to this white paper if you're interested.
Adzim
AdzimZM_Altera
1 year agoHello,
There are some update about the DDR4 memory capacity (component) supported by Agilex M-series and Agilex F/I-series FPGA.
- For Agilex M-series and Agilex F/I-series DDR4 DRAM, the maximum memory capacity per single DRAM is 32Gb.
- For Agilex M-series DDR5 DRAM, the maximum memory capacity per single DRAM is 64Gb.
Adzim
