19 years agoMAXII user flash memory simulation with I2C interface
Has anyone simulated MAXII flash memory with a I2C testbench?
If so, can you share me the testbench? Thanks.2 Replies
I used the I2C megafuction in my design previously and it looks fine. I actually used a I2C kit to interface with the MAX II device to access the UFM. I am using this board:
http://www.demoboard.com/win-i2cnt.htm So far I didn't see any problem. You might want to try this as well. Good luck. - Altera_Forum
It sims fine, based on a very accurate stim that recreated a scope trace of a 24c01 transaction. It did not work in situ, though.
I cannot get altufm_i2c (in Max II) to work in a real i2c circuit. 24c01 works in place. Altera is stumped. Anyone had luck with this function?
