Firefighter's avatar
Firefighter
5 years ago
MAXII Code
Hi Intel,
I am reading some reference code for MAXII CPLD. It is below. I do not understand what it is doing. Any one can help?
maxii_io
d_bit_13(.datain ( sck), //serial_clk_out
.oe (DC2026_DETECT), //DC2026_DETECT=1 SCK_33=sck & gated_sck, DC_2026_DETECT=0 SCK_33=HiZ
.padio (SCK_33), //pin to SCK of LTC2380-24
.combout (B13)); //
defparam d_bit_13.operation_mode = "bidir";
  • Firefighter's avatar
    Firefighter
    Hi, Nurina and SStrell,
    Thanks for help. It can be closed now.
    • Nurina's avatar
      Nurina
      Glad your problem has been solved. I shall close the case now.
      Nurina
  • sstrell's avatar
    sstrell
    This is an instantiation of a module named max_ii_io. datain, oe, padio, and combout are the I/O of the module and sclk, DC2026_DETECT, SCK_33, and B13 are what they connect to in the current level of the design. The defparam is sending a parameter value of "bidir" to a parameter named operation_mode in the instantiated module.
      Firefighter
      Hi Sstrell,
      Thanks for your reply.
      Is max_ii_io module a library or something that Quartus integrated, just like DFF? I tried to search it in the project verilog code, but could not find it. I also search it in the MAXII book. No luck.
      Cheers
      • sstrell's avatar
        sstrell
        Not a clue. This is just standard Verilog code. I don't know where you got it from or where you saw it.
