11 years agoMAX7000 programming question
Hello, please advise - I am starting using MAX7000S device - PLCC44. It has 8 power pins, 4 JTAG pins and 32 user i/o pins. I needed more than 32 pins for i/o, and disabled "JTAG BST support", giving...
11 years ago --- Quote Start --- The MAX7000 datasheets mentions some industry standard programmers (e.g. DATA-IO) supporting it. --- Quote End --- I saw some pictures. They are monsters :) Buying those is just not cost effective. I would better use discrete logic then... --- Quote Start --- I presume there exists a specification of MAX7000 programming algorithm, --- Quote End --- I also thought this way, but found no information about it. MAX7000 datasheet does not have any trace to high voltage information. That seem to be a big secret... BTW, I created support ticket to Altera two days ago and... silence. --- Quote Start --- but I wasn't yet aware of it or any DIY programmer designs. --- Quote End --- That is not a problem :) --- Quote Start --- Today, MAX7000 and MAX3000 are legacy devices and will be hardly supported by new tool developments. --- Quote End --- Agree. The selection was made basing on +5v supply/TTL operating level, and availability on the market. To my knowledge, all later devices are 3v3 max. --- Quote Start --- Requirement of bypassing depends on the involved signal speed and amount of simultaneous switching outputs, I believe. As a standard measure, I would place one bypass capacitor at each VDD pin. I have however an old design with a socketed MAX7032 in PLCC package on a two layer board that works well with a single bypass capacitor. --- Quote End --- Thank you. I had 4 as you advised, but board space became scarce and I had to remove all four while routing adjacent devices. I will see if I still can keep all 4, or will leave two.
