17 years agoMAX7000 power and Slew rate control
Hi All, I have having problems with a simple 15 bit counter being un-reliable - various bits in the top byte appear to change as the bottom byte crosses the 0x00 / 0xFF boundary. This soun...
17 years agoHi FvM,
You are correct, there was a bug in my Verilog, I am still new to this languge. If you can point out what I am doing wrong in this example I will be grateful. Clock was running at 24MHz. The intenet of the design is hopefully quite obvious. Thanks, Mark ============= // Use I/Q shaft encoder input to // control a 16 bit up/down counter // use all available input edges module IQ_interface(clk, I, Q, count); output count; input clk, I, Q; reg last_I, last_Q; reg [15:0]count; always @(posedge clk) begin if(last_I != I) // detect change of I input begin last_I <= I; if(I ^ Q) count <= count + 1; // incrementing appears to work OK else count <= count - 1; end if(last_Q != Q) // detect change of Q input begin last_Q <= Q; if(I ^ Q) count <= count - 1; // decrementing has the bug else count <= count + 1; end end endmodule
