cjamcki's avatar
cjamcki
2 years ago
MAX10DD devices seem to not support ADC Blocks ?!?
we have a design targeting 10M50DDF256I7G. The device overview claims to support analog features as well as RSU, and some special flash access (not sure what that is but whatever). However, in Qsys when you try to instantiate an ADC block (single or DUAL) IP core, it complains that the device doesn't support ADC.
Error: modular_adc_0: The selected device part number 10M50DDF256I7G does not support ADC
The pin planner for this device shows the pins having ADC as a pin option (maybe it's just a visual thing, but still).
If i target a 10M50AD device ("AD" vs. "DD"), it allows the ADC IP to be generated no problem.
So, why can't I use it in the DD device, or is not supported (even though the overview says so).
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    May I confirm with you, for the Max 10 DA device, the design can be compiled successfully with the IP? If yes, can you please share with me the design or else, the IP parameters setting such as the sequencer, etc?
    Aqid
    AqidAyman_Altera
    There is still investigation going on for this issue in Quartus.
    Max 10 with "DD" variant should be the same as "DA" variant but with the additional "flash access control" feature. So, it should have the ADC feature.
    This is likely to be the number 2 options.
    I will definitely update back to you once I got the timeline to avoid this error.
    Aqid
  • cjamcki's avatar
    cjamcki
    this really shouldn't be a difficult question to answer. i see only two options:
    1. the "DD" variant does not not support ADC (documentation error)
    2. it does support it but there's a bug in Quartus/Platform Designer.
    we were hoping to take advantage of the flash options of the "DD" version, but we intend to use the ADC as well.
    we are getting close to ordering components for our program for prototype PCBs, so we really need to know the answer. If it is, the first above, we will just switch to the "DA" flavor and forgo the flash benefits.
    if it is the second choice above, we would need to know when a patch or variable setting or whatever would be available. if it is too far in the future, we'd likely switch to the DA part as well.
  • Pooh_Bear's avatar
    Pooh_Bear
    Any update on this issue?
    I am using the 10M40DD part and have the same problem. Fails to compile with Quartus version 23.1.std
    Error (12252): Adc.modular_dual_adc_0: The selected device part number 10M40DDF256I7G does not support ADC
    AqidAyman_Altera
    Okay, thank you for the information and the design file. I will escalate this issue to the internal team. I will update you back once I got any feedback on this.
  • cjamcki's avatar
    cjamcki
    Quartus Prime Version 22.1 std.0 build 915 10/25/2022 SC Lite Edition
    Patches Installed: None
    this is a windows version. we've had similar issues on 20.1 on Linux
    AqidAyman_Altera
    Thank you for the design file. What Quartus version that you are using?
  • cjamcki's avatar
    cjamcki
    here is a basic project archive. it has nothing in it except an "adc_bad" qsys file. when you open it in platform designer, you'll see that it says the DD device is not supported, and you can't generate HDL due to that error.
    if you re-target to a device with suffix DA, it doesn't complain.
    thanks
    AqidAyman_Altera
    I am really sorry for the experience you had. May I know if you okay to share your design to me either by private or if it is simple design and you don't mind you can share it here.
    I need the .qar file to replicate the issue from my side for further escalation if needed.
    Aqid
  • cjamcki's avatar
    cjamcki
    sorry, the line should read:
    If i target a 10M50DA device ("DA" vs. "DD"), it allows the ADC IP to be generated no problem.
    sorry about that.
