SMS's avatar
SMS
8 years ago
MAX10 UFM Read Operation
I am trying to read from MAX10's UFM but the device does not assert the readdatavalid signal as specified in UFM user guide. Any guess why is it so? I am sharing the relevant code below:
task data_read_top;
	case (read_state)
		FLASH_READ_IDLE	:
			begin
				read_state	<=	FLASH_READ1;
			end
		FLASH_PRE_READ	:
			begin
				if (avmm_data_waitrequest)
					read_state	<= FLASH_PRE_READ;
				else
				end
		FLASH_READ1		:
			begin
				data_read1(00000_0101_1111_0000);
				read_state	<=	FLASH_READ2;
			end
		FLASH_READ2		:
			begin
				data_read2;
				read_state	<=	FLASH_READ3;
			end
		FLASH_READ3		:
			begin
				if (~avmm_data_readdatavalid)
				begin
				end
				else
				begin
					data_read3;
					data_out    <= avmm_data_readdata;
					read_state <= FLASH_READ4;
				end
			end
		FLASH_READ4		:
			begin
				read_state	<=	FLASH_READ_IDLE;
			end
		default			:
	endcase
endtask
task data_read1;
input  [16:0] addr;
begin
    avmm_csr_read			<= 1'b0;
    avmm_csr_write			<= 1'b0;
    avmm_csr_addr			<= 1'b0;
    avmm_data_addr			<= addr;
    avmm_data_read			<= 1'b1;
    avmm_data_burstcount	<=	2'b01;
end
endtask
task data_read2;
begin
    avmm_data_read		<= 1'b0;
    avmm_data_addr		<=	17'b0000_0000_0000_0000_0;
    avmm_data_burstcount	<=	2'b00;
end
endtask
task data_read3;
begin
end
endtask
The task data_read_top itself is called in another case statement. What I have observed in SignalTap II is that it remains stuck at state FLASH_READ3.
  • Shweta_sawant's avatar
    Shweta_sawant
    Please Reply,
    We are facing the same error. Its on priority.
    Best regards
    Shweta Sawant
  • SMS's avatar
    SMS
    Thanks for the reply. My code is attached. Actually I tried simulating the design first but Modelsim gives these errors:
    1. Instantiation of 'altera_onchip_flash_avmm_data_controller' failed. The design unit was not found.
    2. Instantiation of 'fiftyfivenm_unvm' failed. The design unit was not found.
    which I am unable to resolve, so moved directly to post synthesis verification.
    Another thing that I have observed is if I remove the wait condition for 'readdatavalid' signal, it gets asserted by the UFM core and data is shared on the data bus but is mismatched from the address.
    Besides can you explain, that you sent a read request for data to be read from 17'h00000 and 17'h00001 but it seems that UFM read some different data.
    Sarmad
  • SAR's avatar
    SAR
    Not able to understand the state machine can you post full code?
    Have you checked your logic using modelsim?
    I can simulate the Flash IP, it works fine. Attached the image.
    So for debugging check your logic using modelsim first.
    ARS
