jAlter's avatar
jAlter
2 years ago
MAX10 sideways migration
It is possible to perform sideways migration between MAX10 SC (compact feature) and MAX10 SA (analog feature) using the same package, of course, as long as no ADC is used? If so, any special precautions needed on the unused analog pins?
  • Hi,
    I understand your requirement. Since the vertical migration is possible for the device with different logic elements but has the same pinout, it means the device that has the same logic elements and only different in the feature options is also possible to do migration.
    In this case, your requirement is valid for the migration since both have the same pinout.
    Aqid
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you.
  • jAlter's avatar
    jAlter
    You can close the thread. Thank you.
    AqidAyman_Altera
    With the answer provided, do you need more support on this? Can I close this thread?
    Aqid
    AqidAyman_Altera
    Aqid
    • jAlter's avatar
      jAlter
      Thanks AqidAyman, but I'm not asking about vertical migration. I'm asking about horizontal migration, if you want to call it like that, between devices with the same package but different feature options. This is not covered in the documentation, neither seems to be supported by the Quartus Pin Planner.
      Specifically, I want to migrate a SC (single supply, compact feature option) device to a SA (single supply, analog feature option) one, both with the same package, of course. Pinout seems to be same, then it seems that it should be possible to migrate between the two feature options as long as no ADC is actually used. But I would like a confirmation that this migration is possible.
