jAlter
2 years agoMAX10 sideways migration
It is possible to perform sideways migration between MAX10 SC (compact feature) and MAX10 SA (analog feature) using the same package, of course, as long as no ADC is used? If so, any special precaut...
- 2 years ago
I understand your requirement. Since the vertical migration is possible for the device with different logic elements but has the same pinout, it means the device that has the same logic elements and only different in the feature options is also possible to do migration.
In this case, your requirement is valid for the migration since both have the same pinout.
Aqid
AqidAyman_Altera
2 years agoHello,
With the answer provided, do you need more support on this? Can I close this thread?
Aqid
