atattyman
4 years agoMAX10 RSU
My goal is to implement RSU on a max 10 device via the easiest method, performed by a separate uC over some serial interface in which I'm free to define.
My FPGA design is all disc...
GLees
Contributor
4 years agojosephka99 is correct, you do not need Nios to perform RSU, I will warn you, though, you are on a VERY steep learning curve. There are no step-by-step instructions for this approach, you'll have to dig through various RSU examples and decided which "pieces" are relevant to your own design. There are many subtleties to overcome and also bugs to work around. I made it after weeks of frustration. Good luck to you.
