rt52
5 years agoMAX10 RPD file encryption
When I use the convert programming files menu to create remote update files (.rpd) and use AES-128 encryption while generating, do the .rpd files also use the .ekp file when they are downloaded/boote...
JohnT_Altera
5 years agoHi,
Are you using encrypted POF? If yes, then you will need to always include .ekp to program with POF as the erase function will always erase the key and bitstream.
