rt52
5 years agoMAX10 RPD file encryption
When I use the convert programming files menu to create remote update files (.rpd) and use AES-128 encryption while generating, do the .rpd files also use the .ekp file when they are downloaded/boote...
JohnT_Altera
5 years agoHi,
The rpd file will not include the ekp file. The reason is that the rpd file will only contain Max 10 configuration bitstream and ekp is only performed 1 time during the jic configuration.
- rt525 years ago
Ok thank you.
Somewhat related, in ug_m10_config.pdf, it says the key file can be erase via a full chip erase. How do I do this? Doing a normal erase operation just erases the flash, and when I put the .ekp file into the programmer, the erase option is unavailable.
