rt52
5 years agoMAX10 Read Dual Boot IP core values in simulation
I can successfully perform an RSU using discrete logic implementation on a MAX10 device. I now want to confirm that the correct image has been loaded. My board has the CONFIG_SEL pin pulled up so i...
YuanLi_S_Intel
5 years agoAre you saying that you were using 3'h1 in Quartus Design and now changed to 3'b001 and it works now?
rt52
5 years agoThat was the last HDL change I made before it worked. I also added signal tap to look at the registers and saw it go from not working to working in signal tap. I made no other logic/state machine changes and it still does not work in simulation
