rt52
5 years agoMAX10 Read Dual Boot IP core values in simulation
I can successfully perform an RSU using discrete logic implementation on a MAX10 device. I now want to confirm that the correct image has been loaded. My board has the CONFIG_SEL pin pulled up so i...
YuanLi_S_Intel
5 years agoHi,
Sorry for being late, it seems like this IP is not able to simulate. As per the thread you shared previously, customer is also seeing 1111 when there is no image loaded. Then, he / she sees 0010 when image 0 is loaded.
Can you try in hardware and see if it is working?
Thank You.
Bruce
