rt52
5 years agoMAX10 Read Dual Boot IP core values in simulation
I can successfully perform an RSU using discrete logic implementation on a MAX10 device. I now want to confirm that the correct image has been loaded. My board has the CONFIG_SEL pin pulled up so i...
YuanLi_S_Intel
5 years agoUnderstand, wat about the other bit in offset 2? Have you tried to read them?
- rt525 years ago
I have tried to write to offset 2 bit 3 and then do a read from offset 4 and still nothing.
The layout of the documentation isn't clear as to what register is the input register. I see two different sections in the MAX10 configuration user guide. I am reading table 34 for this but there is also tables 9-14 that also have information for the Dual Boot IP but I do not have any of those signals from the Dual Boot IP block that I instantiated.
